Fender sticking out....NEED HELP ASAP
Well I just noticed my drivers side front fender is sticking out a little bit under where the 2 side vents are and above the side skirt....here are a few pics....how can I fix this??
here is a pic underneath...is this whats causing it?? looks like some jackhole tried to jack it up here....i think they did it when I had new tires put on....
What do you guys think?? Can this be fixed?? if so how much??
damnit I swear to god its always something with shops!! Im soooo pissed right now! yeah they will just deny it and say they didnt do it....Jezz whats worse is this was a PONTIAC dealership!!!! you would think they know where the damn jacking points are!!!
Responded to your other post - did the same thing to my car first time I put it on a lift w/o paying attention - and I knew better. All was fine after getting the tabs back in their right location. It's not a jacking point - believe mine says "do not jack here" or something similar on the tabs.
Yeah mine says do not jack here.....
also I did do a search and came up with nothing....
What is wrong with these people who come in and just say SEARCH!!! WTF is a message board for then???? Why even post a reply?? You were 0 help! thanks!
Mine has a smaller version of the same problem. Some cocksuck jacked it up wrong, and I didn't notice it until one day after a wash. By then it had been lifted by several places, couple of tire shops, exhaust shop, shop where I had a solid pinion spacer installed, alignment shop. No telling which douchey ***** did it, but it's not too bad on mine. Only another fbody driver probably would even notice.
Actually you're lucky cause it looks like the fender tab didn't break. It's an easy fix cause the metal is thin. Bend it do you can get to the bolts, unbolt it and straighten the metal tab with pliers, small hammers etc. then bolt the fender back in place and it will pull the fender back in and your lower moulding will sit right too.
