Grinding coming from front of car
Old 03-18-2007, 03:53 PM
mongoose_ss's Avatar
Default Grinding coming from front of car
I have a 01 ss with 100k miles on it. It has a grinding noise coming from the front of the car, it sounds like its coming off th ac compressor or a tensioner and its loudest at idle. my friend has the same noise but his is not as nearly as loud as mine. i was wondering if anyone else has or had this problem
Old 03-18-2007, 03:58 PM
gnomee's Avatar
No idea with that description. If you are sure it is in the belt driven accessories I would pull the belt and turn all the pulley's by hand. If its making noise it will be real obvious which one is doing it.
Old 03-18-2007, 04:17 PM
yeah im pretty sure its coming off the belt driven accessories.I'll try taking off the belt and rotating the pullies.
Old 03-18-2007, 08:42 PM
I took both belts off and rotated the pullies but couldn't hear anything. I decided to change out the a/c belt because it looked a little worn and it seemed to have fixed the problem.
