AC Compressor lines bolt on screw question
Old 04-03-2007, 09:23 PM
shaneatlh's Avatar
Default AC Compressor lines bolt on screw question
What size(length and width) screw is the screw that bolts the lines to the AC compressor.(94 z28) Also if you know the O ring size? Here is a pic The screw is 28 and the O-ring is 18
Thanks
-Shane
Old 04-04-2007, 01:04 AM
2xLS1's Avatar
Bolt, M10x1.5x32. GM part# 15726460
Seal Kit, GM part# 2724577, AC-Delco# 15-2722, 2 reqd.
Old 04-04-2007, 07:38 AM
koolaid_kid's Avatar
Be certain to use the correct seals. They are of the proper material to withstand refrigerant. An oring from Ace Hardware will NOT do the trick.
Old 04-04-2007, 08:46 AM
shaneatlh's Avatar
Thanks Greatly appreciated.
Quick Reply: AC Compressor lines bolt on screw question
