low idle??
What has changed? Are you using the same gas, did you do anything under the hood, etc. Two things control idle, the stop on the TB and the motor and cable on the right fender. Check those too.
The lights dimming etc. is because of the low RPM.
Tha Iac doesnt usually cause a low idle. It will cause a step in idle or a high idle if its sticking. It wouldnt however just idle low period. And the flux of the lights definatly points to a power source or ground problem.
