Low Oil Light
Old 04-13-2007, 01:21 PM
Jon5212's Avatar
Default Low Oil Light
At what point does the low oil light come on? IE 1 quart low... ?
Old 04-13-2007, 01:49 PM
Ferocity02's Avatar
I think like two quarts maybe? Definitely more than one. As long as you have oil pressure you will be fine. The oil pickup is so low you can have fine oil pressure with only two quarts, but hard turns, braking, and acceleration may starve the pump.
Old 04-13-2007, 09:18 PM
bww3588's Avatar
2 quarts or when your wires fray on the end of the sensor. which ever comes first. mine came on and off sparatically with no loss in oil. i had to replace the wires and conncetor to the sensor in the pan.
Old 04-14-2007, 08:37 PM
qwkta98's Avatar
usually on GMs the light comes on when theres 2qts missing
Old 04-15-2007, 04:22 AM
bww3588's Avatar
it comes on when its 2 quarts low. if you had 1 quart or less in your pan, the engine would likely tell you its low on oil before the low oil light did.
Old 04-21-2007, 01:03 AM
connexion2005's Avatar
based on where the sensor is at on the pan you can tell it would come on when it was 2 quarts low like everone else is saying...its slightly higher than halfway from the bottom of your pan
