belt still squeaking...wtf?
Old 04-13-2007, 02:43 PM
jman0322's Avatar
Default belt still squeaking...wtf?
Here's my delima I did have a bad power steering pressure hose but I replaced it and it quit for a while but now it's squeaking worse and there aren't any problems with the water pump or steering pump etc. Do I just need to replace the belt???
Old 04-14-2007, 08:55 PM
qwkta98's Avatar
check the serp belt and the a/c belt
Old 04-19-2007, 11:35 AM
DeadLifter's Avatar
Armor all has stopped belts from squeakin for me.
Old 04-19-2007, 12:18 PM
jman0322's Avatar
I'll try that but it's not like they cost that much so I may just replace the damn thing. I have used pencil lead on the non serpentine belts and that works for a while.
Old 04-19-2007, 12:57 PM
EDS01SS's Avatar
yes just replace the belt and when you do that get some brakleen and clean all your pullies also. you probably still have some oil residue on the belt and the pullies
Old 04-19-2007, 01:20 PM
zoomer02's Avatar
You might still have air in the system since you replaced the pressure line. You should bleed the system by jacking up the front end so both tires are off of the ground. Then turn the steering wheel, with the car off, all the way back and forth 20 times. You should also remove some of the fluid from the reservoir prior to doing this so that it does not over flow. Then start the car up and turn the wheel back and forth a few times, let the car run for a few minutes, the noise should be gone shut her down and lower the car test drive.
Art
Old 04-19-2007, 03:01 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Art
..........Interesting,..........never heard that one before!
Old 04-19-2007, 03:04 PM
sbusby's Avatar
I had a realllly bad squeak for the last week. Changed both belts and a belt tensioner pulley. After a couple days it came back.. I grabbed a belt conditioner soap and put it on for a minute or two, and BAM it's gone.... now I can drive my car without my head sunk down below the door
Old 04-19-2007, 03:08 PM
Originally Posted by sbusby
....... I grabbed a belt conditioner soap and put it on for a minute or two, and BAM it's gone.... now I can drive my car without my head sunk down below the door
.....thats funny,.......hey ....which belt dresser did you use?
Old 04-19-2007, 04:36 PM
EDS01SS's Avatar
a bar of ivory soap works great to
