smog pump p0410, P0418
Im getting P0410 and p0418 when i scan the car....Ive used the search button and looked at the diffrent issues, people were having, I've checked the relays, they were fine, I then checked the AIR PUMP fuse underhood and it was fine. I switched it just to be sure... last issue would be the air pump itself...is there any way to test the pump itself, so i wont waste$$ buying another?
My first thought was just leave everything connected, pull the AIR PUMP fuse and have the codes turned off since you're in California. I'm sure there's gotta be a way to test the pump - look up the codes for your year at www.gearchatter.com for possible diagnostics.
