Leaking power steering, hard to fix? PICS
Well after my two hour fun changing DRL lens I noticed a wet spot on my power steering. It's the part where the lines from the pump go down to a bar that is right above the skid plate. The one line is leaking and possible another as well, over by the driver side tire. Can I just loosen the nut on the lines and replace a seal?
My car goes in to the dealer for that exact problem you have with the stearing rack leak. They are installing a brand new rack under my extended warranty. I figured they would just replace the line.........nope......the rack?
Yeah, that definitely looks like the rack itself.
Mine had the same leak but after I put in some Lucas power steering sealer it stopped.
I know people always badmouth "insta-fix" products like that, but I've seen really great results from the power steering stuff; and not just on my car either.
Originally Posted by alw041
Mine drips and i have to refill my power steering fuild probably about once a month.
I just took my 99 to the shop and had them look at my power steering. It was making a whinning sound and loosing fluid. I had some seepage going on as well. Turns out, there was water in the steering fluid and steering fluid in the radiator hoses. Now I have to replace every hose. I'm not sure if you guys lnow how much those freaking hoses are but try close to $400. On heater hose is $150. This is the car that has the stupid power steering cooler in one of the hoses, which is now being bypassed. Sorry, I just needed to vent about my power steering issue
