Got this LT1 with a vibe *only when braking - LS1TECH
Thread Tools Search this Thread
Old 04-26-2007, 06:50 PM   #1
Default Got this LT1 with a vibe *only when braking
Ok its a 95 lt1, replaced both rotors and pads all the way around and bled the brakes. Hoped to get rid of it by doing that but it actually made it more apparent... Suggestions??
When I drove the car it felt like it was coming from the front left but I could be wrong, but also I felt the pedal surge while giving the same amount of pressure(not hard enough for abs)
Thanks.
projekt70chevelle is offline   Reply With Quote
Old 04-26-2007, 11:01 PM   #2
skifast87's Avatar
could be a tie rod maybeeeee.
skifast87 is offline   Reply With Quote
Old 04-27-2007, 02:16 PM   #3
Yea thats what i was thinking too, my friend just bought the car, ima check for a warped shaft too. anymore suggestions?
Old 04-27-2007, 06:16 PM   #4
If youre feeling the vibration through the brake pedal it's the rotor. Rod ends wont give any feedback through the pedal.
madweazl is offline   Reply With Quote
Old 04-29-2007, 11:20 AM   #5
might sound werid but since after all teh car is 12 years old check to see if the tires are all balanced ok. i remember in winter with the crazy snow one of my tires (they have a pretty deep dish) helod some water on the bottom of the rim and when i went to dirve it vibrated the wheel like crazy
firechicken99 is offline   Reply With Quote
Old 04-30-2007, 03:06 PM   #6
sscrazy's Avatar
rotors
sscrazy is offline   Reply With Quote
Old 05-01-2007, 04:00 PM   #7
When you replaced the rotors, did you make sure the hubs were nice and clean?
Debris, rust, etc mill make it sit crooked on the hub and make it vibrate like crazy.
GMRL is offline   Reply With Quote
Old 05-01-2007, 06:13 PM   #8
00silverT/AWS6's Avatar
I replaced the rotors on my dd and one of the "new rotors" from the autoparts store was warped a little out of the box.
00silverT/AWS6 is offline   Reply With Quote
Tags
braking, felt, g6, pedal, pontiac, shummy, suspension, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
