Newbie Brake????
Newbie Brake????
I just messed up. I was painting my calipers and took both sides out of the rears out. One brake pad surface is longer, one is shorter and has squeler. Which goes towards car which towards tire? I'm thinking long toward car and squealer toward tire but want to double check. Thanks.
P.S. Next time remember don't do both sides at the same time.
Originally Posted by koolaid_kid
As a word of caution to all: When you do your brakes (on either axle) do one side at a time. This allows you to have a frame of reference when you go to reassemble each side. It works for every car and motorcycle you will ever work on.
Back in the day of drum brakes, You would only make that mistake once
Copy & Paste Moderator
Originally Posted by VIP1
I won't buy any new vehicle with drum brakes. Too much of a PITA to work on. Disk brakes not only work better, they are much easier to maintain.
