Headlight problem on a 02 Trans Am
I have an issue after the battery was unhooked. I restored power to the car and now the left side headlight grinds. It also now raises both headlights when you turn on the parking lights. When you now hit the lock, or unlock on the keypad the drivers side headlight starts grinding It totally wacked out. Has anyone had this issue, I also have this issue on my 96 Formula after doing the same thing. It also grinds now on the drivers headlight.
Closed ex-Sponsor Account
Body module might have lost its original settings- look in your owners manual to see how to see up the horn/lights with the security system. The grinding sucks, might just be a coincidence? Good luck
http://www.bfranker.badz28.com/headl...x.htm#Ordering
Same thing happened to my right headlight after my battery died on friday. Try this free fix on the bottom of this webpage, i did it this morning in about 5 minutes worked like a champ.
