P1441 on 97 LT1
P1441 on 97 LT1
P1441- Evaporative Emission System Flow During Non-Purge (GM)
Iv looked online for awhile now and not found much...the dealership says its a 02 sensor...i don't get it. all i know is i used to get about 280 miles per tank..and get 180-210 now.. anyone that can help me would be great thanks guys
I was doing a smog inspection once on one of those LT1's with that same code. It turned out to be the hoses on the purge solenoid were on backwards.
Smog Test Fee 30 dollars
Diagnosis Fee(1Hr Min.) 65 dollars
Getting paid an hour to fix it and taking only five minutes PRICELESS
Here ya go
http://en.wikipedia.org/wiki/Image:1...aroZ28-003.jpg
It's the one with the little red and blue connector in front of the trans fluid dipstick.
Could just as easily be a sticking purge valve or cracked hoses.
Good luck.
Good luck.
It could, anything is possible.
It connects to your charcoal canister which in turn connects to your fuel tank.
Will your gas mileage suffer? Maybe. How much? Couldn't tell you.
It's purpose is to purge stored fuel vapors from your gas tank into your manifold to be burned. Instead of venting them into the atmosphere. It's basically an emissions device.
The soloenoid appears to be bad i think...if i blow threw it should it be open all the time? mine is also..2 hoses that go to plastics lines are cracked so im going to get those ordered. But is the switch/ solenoid bad before i order one? I would think so but want to make sure
