Odd Rotational Squeaking
So I took my car out after winter storage, changed oil, rotated tires etc. After driving it for about 2 days i started hearing a squeak coming from the front drivers side wheel. It only squeaks when the brake is not applied. I don't know what it could be from. Maybe the rim shifting around, or just some rust? Any ideas would be appreciated.
It is possible. On the other hand i bought it. The pads are supposed to have anti squeak grease/spray applied to the back of them. Try some of that it worked for me.
ok so apparently it is not the hub bearing, or the brake pad. It was....Some little "feeler pin". It was a little pin that sits by the pad to let the computer know when it's getting worn. It got bent and was getting nudged everytime the wheel went around. If i can find out the technical name I'll let you guys know.
