50 amp ingnition fuse blowing
Old 05-08-2007, 09:13 AM
z-ya's Avatar
Default 50 amp ingnition fuse blowing
I have been blowing the 50 amp ingnition fuse under the hood on my 2001 z28.Does anyone know what would cause this issue,it just began happening
this year when it came out to play after winter.
Old 05-08-2007, 12:52 PM
staringback05's Avatar
you could have a bad ground, a wire on wire, or a frayed end....check loads on wires..
Old 05-11-2007, 06:12 AM
z-ya's Avatar
I took the odessy battery out put in a fully charged optima red top, drove it to work with no problems.Shut the car off,tried to restart it and blew the fuse again.Put in a new fuse but still no crank.HELP!!!!
Old 05-11-2007, 01:03 PM
blownta00's Avatar
check your grounds man
Old 02-22-2008, 04:58 PM
Black02SLPSS's Avatar
Bringin this one back from the dead. Im having the same problem. z-ya did you ever get yours figured out?
