Airbag question
Airbag question
Im planning to swap out the steering wheel for an aftermarket, along with getting a harness.. however I would like to leave the passenger airbag intact as I dont want passengers to have to deal with a harness. Obviously if you pull one bag, the light will come on... does this light disable the airbag system entirely? Or is it just a warning and the passenger bag would still deploy? Is it even possible to have just one functioning airbag? Thanks for any help
Originally Posted by 618HAWK
Doesn't the SDM do a resistance check of the bags on power up, and if out of range then it set's a fault.
Wonder if finding the correct resistance for the driver side bag.
Then installing a resistor in place would work.
