My Hatch all of a sudden stopped working??
Old 05-15-2007, 10:14 PM
bjamick's Avatar
Default My Hatch all of a sudden stopped working??
Well i went to open my hatch yesterday and it didn't do anything usually it will pop a lil and then ill pull on it and then hit the button again and it will pop up. Well i went and got the Key fob thinking it would open it and it did nothing as well.
I checked to make sure it didn't come unplugged and it was still plugged in so im clueless as to why it wont open. Anyone have any ideas????
Old 05-15-2007, 10:23 PM
bjamick's Avatar
Ok just did a search and found out that the car has to be in park for it to work.
Well i just turned off all my Auto 4L60E codes bc i just installed a TH350, so what do i need to turn back on so the hatch will work??
Old 05-16-2007, 03:22 PM
bjamick's Avatar
any one know????
Old 05-16-2007, 10:50 PM
35th LE SS Camaro's Avatar
I have a bone stock 02 and mine does this as well. I think its a common problem. I believe at installunivercity.com there is a right up how to add a new spring that will make it pop right up.
Old 05-16-2007, 10:53 PM
sloganish's Avatar
i know mine requires i press the hatch button twice to open, but if your is a mechanical problem, ordering a new actuator/spring should do the trick if you cant trace an electrical issue GL
