I think my horn is broke... sounds really wimpy
Don't our cars come with a dual horn? It sounds like only one of mine is working. Not sure what could have gone wrong. Any tips on how to troubleshoot it? Any ideas on aftermarket horns that sound more beefy???
dual horn.... yes... hi and low note... located passenger side under fog light.... there is an access panel 10mm and a 13mm bolt to remove the horn assembly.... pep boys fiamm horn is a replacement.... a few years ago is was a direct replacement but it seems the later model has a revised connector but then again one of my g/f have a g6 and the pep boys horn is a direct replacement.... not hard to hard wire the horn in...took me 15 mins from start to finish
the original horns have a screw on them, sometimes covered by a dab of silicone. turning the screw in/out will change the sound or even make it quit completly if not adjusted correctly. its easiest to remove the horn and test it with a jumper wire while making the adjustments.
