A "moaning/humming" sound when I turn my wheels?
I am getting what I would describe as a moaning sound when I turn my steering wheel if the car isn't moving. It's most noticable when turning the steering wheel to the right, but also a bit when turning it to the left.
I checked my power steering fluid and it's good to go. Any ideas what's causing this sound? I don't mind the sound, but if it's a warning that something is wearing out and someday I won't be able to turn lol, I think it's something I need to look into.
Originally Posted by Kalgorn
Could be your power steering pump crying because you're trying to turn your tires without moving. You should never do that.
And I don't turn my wheels at a standstill normally, I was just doing it to reproduce the noise in an attempt to locate the problem. It also happens, though not as loudly, making slow moving turns such as backing out of my driveway. (which is how I noticed it first)
Originally Posted by 98Camarod
Just because the fluid is full doesn't mean that it isn't bad. Is it harder to turn? Is there play in the wheel? Any leaks?
