idle problem
Old 05-23-2007, 04:26 AM
daniel6718's Avatar
Default idle problem
how are yall getting these things to idle? whats your tps voltage at? i hear you want the iac at 40-60 but mine seems to gofrom 100-130 at startup to 0 after a few seconds and ive tried .70 .74 .76 ect, car doent like to idle that low...and when its cold it wont idle period....and at lights it dies on decel...anything else i need to adjust...
Old 05-23-2007, 04:41 AM
Bo White's Avatar
Whats all dont to the car mod wise? Is this on your 94 Z28?
Old 05-23-2007, 01:48 PM
daniel6718's Avatar
no...its a cam only ms3 ls1 ls6 intake longtubes and a mail order tune/touched up dyno tune for the motor
i had it ok but i never knew you were supposed to adjust the tps back to zero by resetting it...i was simply turning the screw up 1/8 turn at a time...
the idle is set for 950, 5% load in gear i think...
i got it to be fine when warm, but it will occasionally die...this was idleing about 1200....if i go any higher the idle just keeps going up, about 1400 and it surges
cant go any lower it wont idle when it goes into gear....
and when its cold no way...wont idle unless you rev it a few times and let it clowly come back down....
and we have to tap the gas to start it, everytime it starts...
Old 05-23-2007, 02:21 PM
Bo White's Avatar
Reset your idle screw back to stock, unhook the IAC and TPS and turn the key on but dont start it, a couple of seconds later turn key off and rehook the sensors back up. Turn key back on, wait a couple of seconds and start the engine. It will relearn what it can and see what it does and that might fix you up. If it doesnt then you may need a new tune or you may have a sensor bad...if its not a vacuum leak.
Old 05-23-2007, 02:32 PM
SSpdDmon's Avatar
If the IAC counts are 0, the car is getting too much air and the IAC is closed all of the way trying to compensate. At start up (when cold), it's normal for it to be in the 100's because idle speeds are usually higher. To me, it sounds like whoever tuned the car didn't get the idle right at all. Either that or there's a mechanical problem (like a vacuum leak). I'd take it back and tell them what's going on.
Old 05-23-2007, 02:33 PM
TPI_88's Avatar
lol..watt he said....
Old 05-23-2007, 04:57 PM
daniel6718's Avatar
pcm4less did the idle tune, he told me i needed to open it some to get it to idle good, he said get the iac to rear about 40...cant seem to get it to read 40....idk why...its either 100 or 0...and yes i keep resetting it...
if i take it back to stock setting it will simple die...
Old 05-23-2007, 04:58 PM
kistlerjm9's Avatar
ditto
Old 05-24-2007, 02:41 AM
daniel6718's Avatar
another question does yall guys cars start without tapping the gas? i hear if this is the problem then i need to open up the t/b hole..
Old 05-26-2007, 05:22 PM
daniel6718's Avatar
i opened the t.b hole slightly...messed with it more and got it to idle with the iac bouncing between 25-50...let it releard idle and it stayed the same put it in gear and it went to about 110...then went for a drive and the thing died everytime i let off the gas/stopped...whats the problem?
Old 05-28-2007, 02:42 AM
daniel6718's Avatar
ttttttt
