need help fixing turn signals
Okay I checked all the bulbs they are good.....checked the fuse its good.....tried a new turn signal flasher, it didnt fix the problem
It started this morning the left side turn signal when I turned it on the light just stayed on didnt blink.....after I got off work in the evening the right side started doing the same thing
When I turn on the hazzard lights only the rear ones work
Any ideas what it could be ?????
Its on my 2001 SS CAMARO
I replaced the hazzard flasher...... now the rear signals work but the front ones still dont blink
I took the flasher I bought for the turn signals and put it on the hazzard flasher....i think i will try and put a new one on the turn signal flasher and see what happens
Each bulb has two filements, one for the parking lights and one for the turn signals. Chances are your turn signal filments are burned out. Replace the bulbs and see if that doesn't fix your problem.
hey I think u answered me on both sites ! thanks man
problem fixed
