Changing Fuilds
Old 05-28-2007, 11:07 PM
kraemer94's Avatar
Default Changing Fuilds
Hello All! I just bought my 2001 SS and want to change all the fuilds to Royal purple. I used it on my 1995 Camaro with no problems but I been running from the time I bought the car new. The SS I just bought has 57,000 miles on it. What do ya'll think about changing the trans fuild? I been reading alot and some people say not to mess with it?
Old 05-28-2007, 11:12 PM
2001 White Ws6's Avatar
Most will say not to use a synthetic trans fluid.
Old 05-28-2007, 11:15 PM
cookba's Avatar
dont use synthetic tranny fluid
Old 05-28-2007, 11:44 PM
Shatterz's Avatar
I don't see anything wrong with changing it. Just don't take it to a shop with one of those transmission flush machines. And like others said, just use regular transmission fluid, NOT synthetic.
Also, there are much better fluids out there than RP, especially in the motor oil department.
Old 05-29-2007, 01:17 AM
staringback05's Avatar
why do you want to change everything to royal purple? theres plenty of good fluids out there...
put the same fluid that went into the tranny, back in...(type)...make sure you flush it to
Old 05-29-2007, 01:19 AM
waldershrek's Avatar
Why should he not use synthetic tranny fluid?
Old 05-31-2007, 08:20 AM
idrivefast22's Avatar
wondering the same thing...
Old 05-31-2007, 08:34 AM
Weezzer's Avatar
My understanding is because the syncros are paper lined and the synthetic fluid tends to disolve the lining thus requireing syncro replacement.
Old 05-31-2007, 08:37 AM
jond99's Avatar
Been using mobil 1 atf for close to 80k, tranny (m6) still running strong.
Old 05-31-2007, 10:33 AM
WFOWS6_IL's Avatar
Been using Mobil 1 for awhile and no problems. Will continue to use.
Old 05-31-2007, 10:51 AM
waiting2bl33d's Avatar
i thought this was a pre-00 t56 theroy.
Old 05-31-2007, 12:52 PM
02SStreetmachine's Avatar
BIG NO NO FOR ROYAL PURPLE....atleast not the motor.....just blew mine after i ran RP.....went to RPM, they told me I should have never used it.....has happened to alot of people's motors.....Mobil 1 for engine oil....
Old 05-31-2007, 01:30 PM
Starion's Avatar
Not sure whether your SS is an A4 or m6. I don't subscribe to the notion of not changing it if it's an A4. When I bought my car the fluid was old and made it feel like it had a shift kit in it. Flushed it and put new fluid in and it's great now.
Old 05-31-2007, 03:49 PM
Greggy's Avatar
I do the home flush method every 20k, taking off the cooling hose to the radiator, and use only regular dexron III / mercron fluid. About 10-12 qts. per flush. The new universal fluids everyone is putting out are not optimized. I just found some old penzoil for $2.
GM did not use synthethic in any 4l60e that I know of and the regular **** works great on the cheap. "If it ain't broke"
Old 05-31-2007, 09:23 PM
Weezzer's Avatar
I hate to tell you but in the LS1 the Mobil 1 isn't much better than RP. My used oil analysis on the Mobil was terrible all three times I used it.
Old 06-09-2007, 11:53 PM
kraemer94's Avatar
Default Royal Purple
I have used Royal purple in all my cars and trucks with no problems. I have another Camaro bought new and now have 187,000 miles and still running. I was just wondering about the trans fuild because I bought this car used. I didn't know what the other seller used in the trans. Are if he ever even had the fuild changed at all.
Old 06-11-2007, 03:08 PM
Dal1as's Avatar
Only some of the 98 transmissions used paper syncros. Our cars use carbon based syncros. Synthetic fluid is fine.
