How To Replace Front Turn Signal Bulb
Old 06-02-2007, 05:43 PM
Z ROADSTER's Avatar
Default How To Replace Front Turn Signal Bulb
ANYBODY?
What all do you have to dis-assemble to get to the damn bulb ?
Old 06-02-2007, 06:09 PM
blackztwty8's Avatar
i usualy get under neith the car, unscrew a few screws that are on that side, reach my hand up twist out the part the bulb plugs into and plug a new one in, twist it back in, screw the screws back and ur done 10 mintes max
Old 06-02-2007, 06:57 PM
1WICKDZ's Avatar
If its a camaro I just unscrewed the 1 bolt that held the headlight there and it was REALLY easy after I removed the headlight.
Old 06-02-2007, 07:42 PM
Z ROADSTER's Avatar
Yeah, its a 02 camaro.
Thanks, I'll try ya'lls suggestions.
Old 06-02-2007, 07:59 PM
cookba's Avatar
dont you have to recenter the headlight after pulling it off though?
Old 06-02-2007, 09:31 PM
Z ROADSTER's Avatar
I hate to pop your bubble dude but obviously you've never removed the passenger side headlight assy on a 2002 Z/28.
Old 06-02-2007, 10:51 PM
1WICKDZ's Avatar
I didnt take out the assembly, just the lamps. It had one long screw going through the middle holding it in. Wasn't a big deal, might of just been mine I dunno.
Old 06-02-2007, 10:58 PM
cookba's Avatar
i have to do mine tomorrow. im just going to put it on a lift and get at it from underneath. my drivers side is out, but im doing both side for safe measure.
Old 06-03-2007, 01:14 AM
do what i told u go from underneith that way you don't have to mess with ur head lamp
Old 06-03-2007, 01:38 PM
Z ROADSTER's Avatar
Default Need Pics
Could you take a pic of the trap door please?
Thanks
Old 06-03-2007, 03:32 PM
RandomOmen's Avatar
I just reach through the air intake holes underneath the housings; but, I drive a WS6 so my front fascia is a tad different.
Old 06-03-2007, 03:59 PM
i will take some pics...don't have my digi with me though!!! i was thinking about it when i first posted!!!
let me know ill still put some up
Old 06-03-2007, 04:08 PM
jond99's Avatar
You don't need pics, just look under your front end. You will see a closed flap that has two screws attached to it, unscrew and the flap falls out. Within 5min. you can change both turn signal bulbs.
I have never heard of taking out your headlights to change the turn signals, that is insane!!!!
Quick Reply: How To Replace Front Turn Signal Bulb
