I may have broken valve springs... Help please
Old 06-28-2007, 09:51 PM
xxtheonlyxx's Avatar
Unhappy I may have broken valve springs... Help please
Symptoms...
Normal driving from a stand still...
Car goes lean.
Chugs air in and bucks like the cam has an insanely large lope.
Rattling sound coming from the passenger side of the car.
Car stalls constantly, even though the tune is exactly the same.
Last time I went WOT it went rich. So rich that my a/f gauge couldnt give me a reading.
The first time it happened the service engine light started flashing, but when I ran the codes nothing was there. My a/f is all over the place, and I just replaced my o2 sensors thinking maybe the race gas messed them up. Changing the o2 sensors, and checking the tune didnt do anything.
I'm wondering if I may be another valve spring victim. Is this how a car acts when a spring breaks and drops the valve? I have the comp cams valve train upgrade kit that included ls1 high performance valve springs (#26918).
Old 06-28-2007, 09:56 PM
bluehawk2's Avatar
I don't know exactly what a car will do when a valve spring breaks, but I know I wouldn't crank it back up until I pulled the passenger side valve cover off to see.
Old 06-28-2007, 10:01 PM
Slo-Mo-Shun's Avatar
If the valve spring broke, the valve would drop and the piston would be hitting it...
you would also have misfires because the valves wouldn't be closed for the compression stroke.... Valves would be bent and pistons would have damage.
Very loud metallic sound... And you would hear it anytime the engine is running.
Old 06-28-2007, 10:13 PM
It was throwing off misfire codes a few weeks back. My tuner couldnt pinpoint why, but thought it had something to do with the a/f o2 sensor issue. For the service engine light to be flashing it had to throw off some kind of code.... why would it clear the codes out by itself???
Old 06-28-2007, 10:15 PM
Thanks, so its a definite that the valve wasnt dropped
Edit: Bingo!!
I spent an hour searching, then I find this right after I start a new thread
Originally Posted by MOBE
At idle it will most likely sound fine. When you drive it "normally" it will sound like you have an exhaust leak ("tick") and will sputter and hesitate. If you floor it it will backfire and sould horrible.
This is all of course, if it is an exhaust valve. I had to change one last weekend. Never had a broken intake valve though.
Old 06-28-2007, 11:03 PM
Please let us know what you find..... now I'm curious
Old 06-28-2007, 11:35 PM
Will do, I'll have it apart next week
Old 06-29-2007, 05:28 AM
staringback05's Avatar
hows the oil look/smell?
Old 06-30-2007, 03:37 AM
speeddemongto's Avatar
918's strike again
Old 06-30-2007, 07:27 AM
melchoir's Avatar
Originally Posted by speeddemongto
918's strike again
He hasn't opened it up yet, so we have no idea what's to blame.
Old 07-01-2007, 11:22 PM
The 918's look fine? I'm honestly not sure what it could be.
Old 08-21-2007, 03:22 AM
2 bad spark plug wires, 1 bad spark plug, and bad O2 sensors cause the car to act the way it did...... Updated just in case someone searches and finds this later.
