Which Oil would you recommend?
Old 07-02-2007, 07:04 AM
LS1 Melly's Avatar
Default Which Oil would you recommend?
I am a life time, die hard Castrol user. Changing the Formula's oil for the first time. Is it best to use Syntec 5W30?
Old 07-02-2007, 08:37 AM
six_string_wiz's Avatar
I think youll be fine with that.Its suggested from factory I think,but mobile 1 brand.
I use Royal Purple 10w40 here in AZ.In the winter I drop to 5w30
Old 07-02-2007, 08:44 AM
03 BUSA's Avatar
Mobil 5w-30 sythetic is my choice.
Old 07-02-2007, 09:16 AM
coolformula's Avatar
Mobile 5-30 is too thin.
use 5-40 or
the best is the German Castorl 0-30W and that way u stick with the brand you love.
Old 07-02-2007, 11:09 AM
LS1 Melly's Avatar
I could never see myself buying Mobile. Anyone had bad experience with Syntec?
Old 07-02-2007, 11:17 AM
LS1 Melly's Avatar
..... And if I go with Syntec, 5w30?
Old 07-02-2007, 11:20 AM
dailydriver's Avatar
IF(and that's a BIG IF in some areas, but you'll have better luck in the southern portions of our state, it seems) you can find it the GC (German Castrol 0W-30) is one of the best. For summers in our area; the BC (Belgian Castrol 5W-40, even harder to find than the GC!!)
If not, in order;
Redline 5W-30 (winter), 1/2 5W-30 & 1/2 10W-40 (summer)
Amsoil 5W-30, or Series 3000 5W-30 (winter), Euro 5W-40 (summer)
Pennzoil Platinum 5W-30 (winter), 5W-40 (summer, again, IF you can find this, the ONLY place I've EVER seen it is in NAPA stores)
PennzPlat is the definite "bargain" of the oil world, EXCELLENT stuff and they are almost paying you to use it when you get the $15.00 rebate deal from Pep Boyz (it prices out to $1.99/quart on that one!!!!! ).
The regular old Syntec 5W-30 is NOTHING special, probably only slightly better than Mobil 1 5W-30. For less $$$ I'd rather go with the Pennzoil Platinum mentioned above, if you don't want to go with the others, or can't afford/find them.
Old 07-02-2007, 11:57 AM
Sharpe's Avatar
EDIT: Was in Advanced Tech.
Old 07-02-2007, 12:07 PM
Mr Incredible's Avatar
use 5-40 or
I disagree with the classification of M1 5w-30 as thin.
Mobil1 5w-30 viscosity is better than mid-pack in the 30w population, not at all what I'd call "thin".
And as for advising a thick oil, my LS1 just got an excellent oil analysis from Havoline Deposit Shield 5w-30. That oil is the next to lowest viscosity I can find in the 30w range. It was a short run, granted, but the trend was outstanding. See the used oil analysis here.
In fact, I have Castrol Syntec 5w-30 in the car right now. This oil IS the lowest visc 5w-30 I can find.
At least on one LS1, thin oil is not an issue at all, and I'd dare say it's an old wive's tale that may need another look...
Old 07-02-2007, 01:06 PM
Yea I seen your post in the other theard after I posted here..interesting. Still would like more data.
but we all we know GC can't go wrong there and its a great oil.
Old 07-03-2007, 09:10 AM
lets_fly's Avatar
Mobile 1 Baby!
Old 07-03-2007, 09:14 AM
LS1 Melly's Avatar
So in all, I will be safe with Syntec it looks like.
Thanks guys!
Old 07-03-2007, 11:53 PM
waldershrek's Avatar
It seems to me you planned on using it all along anyway
Old 07-04-2007, 12:13 AM
slowpoke96z28's Avatar
Old 07-04-2007, 12:50 AM
Quickin's Avatar
Non synthetic, regular ole' oil thats been used for 100 years. 20-50, whatevers the cheapest.
I've got 80,000+ miles on my 436 stroker and she's purring like a kitten with 58psi of oil pressure on start-up and NEVER ever less than 40psi.
Oil is all hype. Kind of like air filters.
