Wiper fluid Question?
Old 07-05-2007, 09:28 AM
2001somws.6's Avatar
Default Wiper fluid Question?
I been having an issue with my wiper fluid not coming out of the hole on the drivers side hole but only comes out very week on the other side. Anyone have or had this problem and fixed it?
Im thinking it my just be clogged but it might be something else. Any ideas?
Old 07-05-2007, 11:05 AM
67rsss's Avatar
Pull the hoses and try the pump. If it squirts fine through the hoses, you have clogged nozzles. If it isn't coming out of the hose strong, you have a bad/failing pump.
Old 07-05-2007, 03:45 PM
Thanks for the info. I looked at the part that connects to the wiper fluid and pushed down on it and then i tryed it and now the SOB works just fine. Must just have been loose.
Old 07-05-2007, 06:16 PM
ErikElvis's Avatar
Sometimes if your not a careful waxer those suckers get clogged.
