Vibrations under car?
I feel a weird deep and heavy vibration under my seat when i'm in the 2000-3000 rpm range. then it goes away when the rpms go higher. what is that? driveshaft? broken torque arm? is that just me needing an alignment?
at what speeds are you going? sounds like it could be driveshaft imbalance or worn u-joints. it could even be your tires either being out of balance or cupped/scalloped.
yeah, you may want to check your local trans shop to see if they could re-balance it. according to your sig, looks like you've had quite a few mods and trans work done. sound's like you've got yourself a pretty sweet ride.
Fiery Features Director
Can you feel anything in the steering? Is it affected with just RPM, engine speed or both? If the problem is an unbalanced driveshaft, the vibration will usually get worse at higher speeds. The vibration you describe could also be an unbalanced torque converter.
i can get my torque converter balanced? how?
the vibration doesn't effect driving or the motor, it's just annoying to feel. car seems to be fine right now but i noticed a lot of fluid under the car where the oil pan was and under the tranny. it's not dripping on to the ground but it's def leaking. looks like it came from behind the motor, maybe rear main seal? but would that effect driving and cause vibrations? maybe it's a combo of things! my car is sick!
the vibration doesn't effect driving or the motor, it's just annoying to feel. car seems to be fine right now.
As far as the fluid goes... what color is it?
yeah the converter has been in for some time now and this just started happening. the fluid is fine and doesn't look burnt at all. it has been changed out once since install recently as well.
could a cracked motor mount cause that vibration? i was told my drivers side mount was cracked by my mechanic but that i could get away with it until i could afford new mounts. what do you think?
