Car died :(
Old 07-09-2007, 10:13 AM
dsmith09876's Avatar
Default Car died :(
WEll i was on my way out last night with the girl and im watching my voltage go down and down and down so i start heading home and my gauges turn off then it starts boggin out about half way so i pull over and check by this point its still running but i shut it off. then i try to start it agian and it sounds like the battery is dead so my dad came and gave me a jump an let it charge for a little then i raced home with it and made it... barely.... i charged the battery all last night and it starts right up this morning volts are right were they should be high 13's to 14 and i start driving up the street and down t ake it for a ride and it seems ok the volts when i came back were at about 13.6 and it started at 14. Im really not sure if its an alternator or not because i was gunna rip that out thismorning and throw another in but now im thinkin it could just be the battery?? im not sure how old the batt is but its an optima battery it seems pretty new i just got this car about 3 or 4 months ago...ive heard that there is a litte red wire on the alternator and if that comes loose or undone it coudl cause low voltage problems and im going to go check that. if any one has any advice i would appreciate it thanks
Old 07-09-2007, 10:16 AM
mattraypharbor's Avatar
alternator is gone get a new one.
Old 07-09-2007, 10:21 AM
i have had alternator problems before in my truck and when it dies it diesn nothing no lights no nothing the lights could turn on and **** but it might have been running off the battery idk
Old 07-09-2007, 10:35 AM
darom's Avatar
Before replacing your alternator, start your car and measure the voltage on your battery with a voltmeter (the gauge inside the car is not accurate). If it shows constant 14.4-14.6V, your alternator is working. Next step have your Dad rev your engine RPMs, see if the voltage stays at about the same level. Take the car for a test drive, come back, let the car idle, repeat the same test.
Make sure all the ground cables have good clean terminals, check the positive cable from the alternator going to the battery. Your can check resistance on that cable as well (engine off).
Old 07-09-2007, 10:39 AM
tylerdj's Avatar
Autozone or most part stores will test your battery and alternator for free.
Old 07-09-2007, 11:22 AM
auto zone is garbage yeah i wasnt looking at that gauge i have another one and its digital and says it but yeah ill try thanks
Old 07-09-2007, 11:24 AM
tylerdj's Avatar
Everyone knows they're garbage, but they can test a battery just fine.
Old 07-09-2007, 11:31 AM
lol yeah
Old 07-09-2007, 11:47 AM
Alt
Alt's Avatar
Now what happens if when you rev the car a little and when its comming back down in rev's the voltage takes a considerable drop and then goes back to normal. Is that also an alternator issue?
Old 07-09-2007, 11:57 AM
Jon5212's Avatar
Yes it sounds like the voltage regulator is going out or bad diodes. Autozone can test your alternator, they hook the machine up to your car running and it puts a load on the electrical system.
Old 07-09-2007, 12:19 PM
Alt
Alt's Avatar
Thanks Jon, looks like I have another thing to add to my list of parts.
Old 07-09-2007, 12:32 PM
jman0322's Avatar
I just went through the same thing and it was my alternator. Mine was caused by the power steering leak I had though. Be careful though because there is no slack on that red wire.
Old 07-09-2007, 04:10 PM
well i just ripped the altoernator out went to autozone to get a new one got the old one tested and it was good so i thouhgt it was the battery brouught that down and it was good toop... any ideas????
Old 07-10-2007, 11:10 AM
Jon5212's Avatar
Thats weird, maybe you have a bad ground then?
Edit: If it cranks over and holds a charge your battery is good... so I'm thinking maybe the tester is faulty at autozone for the alternator or you have bad ground. Because when the engine is running it does not rely on the battery for power unless your alternator quits.
Old 07-10-2007, 11:12 AM
darom's Avatar
Make sure all the gound cables and a positive cable are good, clean and show little resistance. Find the ground cables going to the block, check those. Definitely re-check the positive cable going from your alternator to the battery.
