A4 shifter handle and console removal questions...
get a screw driver flat head and pry out the staple behind the shifter, lift it off, unbolt all the bolts in the console compartment (4 i think) and the upper part should lift right out. then there are a few more bolts holding down the lower section. put your shifter in 1st gear and the parking break up to make it easier to lift it all out.
Copy & Paste Moderator
In the front of "tail" of the the shift **** (facing the radio), there is a slot with a staple just like WS6NIGHTMARE said. Pry out the staple and pull the handle up to remove it.
