Oil Cap stuck!
Old 07-11-2007, 10:09 AM
freshduckie's Avatar
Default Oil Cap stuck!
Has anyone ever have this happen. This is not a LS1 but I do own one of those too. I cannot get the oil cap off the valve cover on my 98' Cheerokee Sport. I try to loosen it and it just spins and clicks (same click you get when you overtighten a oil cap or gas cap). Is there a tool or a easy way to get it off without removing the valve cover?
Thanks alot,
Doug
Old 07-11-2007, 11:51 AM
Arc00TA's Avatar
Its pretty simple, I had it happen all the time on my CJ after I put the newer style valve cover on with a new cap. All you need to do is get a screwdriver under the edge of the grip part and pry on it, it will pop out leaving the actual plug in there. Then get a pair of pliers that fit around the edge of the plug and turn that bitch. You may need to get a new cap if it wont snap back together properly, sometimes the teeth break.
Old 07-11-2007, 12:15 PM
Ok that sounds like a plan, thanks
Old 07-11-2007, 12:17 PM
Arc00TA's Avatar
Good luck with it.
Old 07-12-2007, 12:26 AM
burnrubr88's Avatar
exactly what I was gonna say. just pop the damn plastic piece off and then use some pliers or channel locks and then replace the piece of **** cap with a cheap all metal one from advanced or somewhere and never have to deal with it again.
Old 07-12-2007, 12:56 AM
waldershrek's Avatar
I used to have to do this when I worked in a shop and couldn't get them off.....can be frustrating but just be patient
Old 07-12-2007, 10:35 AM
Thanks for all the replys
Old 07-12-2007, 10:44 AM
Black 99 Bird's Avatar
This must be pretty common for Jeep's, it happened to my boss's a few year back.
Old 07-12-2007, 12:06 PM
burnrubr88's Avatar
yep happened to just about everyone I had to work on.
Old 07-12-2007, 01:09 PM
Arc00TA's Avatar
Yeah, especially happens if you try to take the oil cap off with the motor still warm. Stupid plastic valve cover.
Quick Reply: Oil Cap stuck!
