Car hits puddle and f's up everytime
Car hits puddle and f's up everytime *UPDATE*
Hey guys, quick q.
My car is low (on sportlines) has msd wires, longtuves etc. Everytime, and I mean evertime I hit a puddle more than 3 inches deep the car starts running like ***. Clutch feels real spngy it does'nt want to rev and just runs like ***, hesitating and stuff. Sometimes the ses light comes on.
To fix it I usually let it sit a couple hours it seems to dry out then and run ok. It's just really annoying. Like everytime I hit a puddle I have to limp it after that going like 20 mph.
Any idea what that water keeps hitting or getting into? I'm thinking battery or plug cables but I'm not sure. The clutch thing throws me off because it feels real spongy when it starts doing that.
Thanks
Thanks
haha i used to have sportlines and went through the same **** man. those are your O2s getting wet. when they're wet they won't read properly and your car will run like *** (it feels real laggy, right?). it is time for new ones! get the bosch ones from autozone. if you have a true dual exhaust setup get the bosch O2s that are for a C5 corvette. they're longer so you won't need extensions! also check your car for exhaust leaks, i'm sure you've got some if you have the sportlines. bottoming out will definitely cause leaks.
to fix the problem permanently, get the prokit and ditch the sportlines. honestly the prokit looks like the sportlines once the shocks sag a bit. so you'll retain the look of the car and you won't be bottoming out anymore!
water gettin in the intake possibly causing the engine to misfire and throw a code. maybe the loss of power causes your clutch to become spongy? i know when my daily driver is about to stall the power steering turns really easily for some reason. Get your codes checked out and good luck.
No go on the pro-kit. I had them before these and did'nt like it lol. Car sits nice now but I have this **** to deal with.
Thanks guys. I guess I'll try some new o2 sensors, or just really avoid these damn puddles but im in FL so it rains every freakin day lol
i have the same problem whenever i go through a puddle. water must be getting sucked up through the filter and on the MAF. the engine misfires of and on until it dries out. after that the SES light turns off and it runs normal.
So yesterday I hit a puddle and same old thing. Excpet this time, I start it up this morning and it's still runing like ****. It did'nt dry out.
So I take it up to the loacl place to run the code. They get misfire. Look at the plug wires and one of my MSDs is sitting right on the header. It has a nice burnt/crispy hole in it. So everytime I'd hit a puddle, water would hit that thing. Yea, I'm a tard.
So, I got 7 MSDs on there and 1 stocker. Is that going to be an issue? I doubted just wanna make sure because I dont think MSD sells individual wires and I dont feel like buying a whole set right now.
Thanks.
Thanks.
