seafoaming question
seafoaming question
yea i went to seafoam my 01 t/a and when i pulled the brake booster vaccum hose it didnt rev up to like 2000 or 3000 rpm like it said in the write up it actully was idealing low and was seeming like it was about to stall out my engine so i stopped right there and didnt do it why is that it didnt rev up high like that?
well when i pulled it off it shot up to like say 1500 then quick dropped to 500 rpm i would say so i didnt evne pour any in so you are saying thats normal?
When I did mine any time I would try to disconnect the booster line the engine would die instantly. I had to use a pair of vise grips (with some cardboard to protect the rubber hose) to hold it almost completely shut so the engine wouldn't stall, the small opening was still enough to feed the Seafoam in. Hope this helps.
it does help when i read the sticky it said the ideal should be at like 2000 or 3000 so thats why i got worryed about it. and just to make sure you are supose to use half of a sea foam bottle or just quater of it?
I have the car off, and pull off the booster, hold the cup of seafoam underneath, turn on the engine, it sucks it all up and kills it. Replace the booster, wait 5 mins.. start it up (might need a lil gassing) and enjoy the smoke
Originally Posted by purple98haz28
so does this really make a difference to power and mpg. i know it depends on the car but i am thinking of doing it to my 125k ls1. any drawbacks
Any commnet would be great since i really want to do it just sacred of the consequences. Thanks.
yeah, typically a huge vacuum leak will make the car die. just put ur finger over the hose while its disconnected from the booster and pull ur finger away to suck in the seafoam.
ttt can i use at 120k +
