Security problem....
Old 07-22-2007, 12:44 PM
Lt1owner's Avatar
Default Security problem....
Sometimes when I get in my car it wont start and the security light just stays on. After about 3 minutes or so it will go off and the car will start. How can I fix this?
Car is A 2000 TransAm.
Old 07-22-2007, 12:56 PM
2001NBMZ28's Avatar
Sounds like it's not recognizing the key pelet resistance - first thing I'd do is try another key or clean the one you have. If that doesn't work you'll need to get it fixed, or do a VATS bypass - you can also have VATS turned off.
Old 07-22-2007, 01:08 PM
Lt1owner's Avatar
How can you turn vats off? Is it difficult to do or what?
Old 07-22-2007, 09:29 PM
GOaT Cheese's Avatar
You may need a new lock cylinder. There are a pair of very fine wires that attach to the cylinder, they often break under the insulation and cause the problem you are describing.
Old 07-22-2007, 09:35 PM
Havok2's Avatar
they sell a vats bypass kit o ebay, its like 30 bucks..wondered if i should get it...
how about you get it and tell me how it works
im having same issue now, but car wont start at all.... just light stays on, then goes off
Old 07-22-2007, 09:36 PM
Havok2's Avatar
goatchese: if i bypass the vats, do i still need to fix the lock cynlinder, or no, since i bypassed it?
Old 07-22-2007, 09:45 PM
No, if you bypass it with a resistor, then you can leave the cylinder alone.
Old 07-24-2007, 09:01 AM
Nitto98's Avatar
Default i wouldnt bypass the vats
thats the only thing keeping sumbody from using pliers to break your swtch over and taking your ride! either way, i would just get a brand new code cut vats key w the resistor. the resistor might just be worn down and doesnt give the computer enough time to determin the value yet before you crank it! wouldnt bypass it tho, i could steal your car in 2 minutes if i was a thief!
Old 07-24-2007, 07:09 PM
It's not going to be a pelet problem. I guarantee you it's the cylinder.
Old 07-24-2007, 10:07 PM
grnapples's Avatar
i have the same problem ill get in and put the key in and the security light flashes all accesories and power steering works (well about as good as it works usually) but hte engine wont even attempt to crank. PLZ someone in my area help new owner and i dont know squat about camaros thnx
