Trunk rattles bad
Old 07-24-2007, 05:43 PM
Javictory's Avatar
Default Trunk rattles bad
every time I hit a bump or something the back trunk rattles bad...1997 trans am
Old 07-24-2007, 06:00 PM
2001NBMZ28's Avatar
Not something loose in the spare tire area is it?
Old 07-24-2007, 06:14 PM
Javictory's Avatar
Ive tighten everything in that area, but the noise sounds like the rear trunk rattling up and down only when I hit a bump or something...very annoying,
Old 07-24-2007, 09:59 PM
JEB Garner's Avatar
Due to the age of your car, I think in order to stop the rattle, you should look into replacing the weather stripping aroung the trunk lid.
Old 07-25-2007, 06:09 PM
Formula413's Avatar
Another thing you can try is adjusting the two rubber bumpers. If you look at them you will see they are actually threaded in. If you back them out a little that might make it shut tighter.
I am getting an intermittent noise from back there too, I think in my car it might actually be the amp.
