How do I get the lumbar adjustment to work on drivers seat?
As the title says. I have the power front seats in my Firehawk. The passenger side works, it pumps up and down for the lumbar adjustment.
The driver side doesn't work. I just hear a clicking from under the passenger seat. Is there a relay or something? I have no idea where to start. Thanks for any help.
((((((Administrator))))))
If the passenger's side works then your driver's side should work. The air pump for lumbar for both seats is under the passanger's side.
Unbolt the driver's seat and lean it back and take a look at the underside. Maybe the return airtubes popped out (also check passenger's side for leaks)?
But if you hear like a "clicking" electrical sound it might be your switches. The whole lumbar system works if the passenger's side works, just look for a leak in the air tube or a bad switch.
Good luck,
Craig.
P.S. -This belongs here in the General Maintenance & Repairs section, not the General LSX Automobile Discussion section.
Good luck,
Craig.
Well I fixed it today. As my dad said, if all else fails, make sure it's plugged in. Under the driver seat the connector had come undone. I plugged it back in but its really really tight. There isn't enough hose or something. I moved it and made it a little better. I will keep an eye on it.
Maybe my back won't hurt as much now since I can inflate it.
Cheetoh,
Do both seats not deflate? If it's just the driver side it could be the switch on the driver seat.
Cheetoh,
