Front hub assembly
Old 07-29-2007, 10:45 PM
SSsuperdave's Avatar
Default Front hub assembly
What is the correct procedure for servicing the hubs,if any. Are they servicable or do you just replace them? What is the service intervel for these?
Old 07-31-2007, 02:14 AM
2002_Z28_Six_Speed's Avatar
What do you mean?
Replacing studs? Replace the wheel sensor (non serviceable)? Replacing the bearings (get new hub)?
Old 07-31-2007, 02:59 AM
DaddySS's Avatar
They are sealed and non serviceable. If you have a problem with them, the hub bearing assembly and seal are replaced as a unit.
