help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! can't read odII port-car is random missfires
Old 07-31-2007, 01:40 PM
sick01ws6transam's Avatar
Default help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! can't read odII port-car is random missfires
the car has 10.4 taylor wires bosh 02 and irridium plugs.
the car will drive fine one min and bad the next. The car will back fire and shoot flames out. I went to have the codes scanned but the tech 2 wouldn't read it like the obdII port wasn't getting any power!!!!!!!!!!!!!! please help!!!!
Old 07-31-2007, 01:51 PM
2001NBMZ28's Avatar
If you don't have any power to the DLC check and see if the CIG/ACCY fuse is blown.
Old 07-31-2007, 04:23 PM
thanks will check!
Old 07-31-2007, 05:10 PM
Eurospec2's Avatar
If that fuse is good, with your symptoms it very well could be your PCM has gone south
Old 08-06-2007, 07:55 AM
the fuse was bad, but the car still is miss firing
i replaced the plugs and o2 s
Old 08-06-2007, 07:56 AM
the only code the car had was bank 1 sensor 1 rich or low voltage
the miss fire comes and goes
Old 08-06-2007, 07:57 AM
the car will be driving great and out of no were it will start miss firing
Old 08-07-2007, 05:05 PM
Does Any Know If A Knock Sensor Will Cause This Even If It Is Not Puting Out And Codes?
Old 08-07-2007, 05:34 PM
2001NBMZ28's Avatar
A bad precat 02 sensor can cause problems. What makes you think it's a knock sensor? Scan the car for current codes.
Old 08-13-2007, 04:13 PM
The Car Has No Codes. It Is A Heads And Cam Car, So A Lot Has Been Tuned Out. When I Put The Laptop On The Car The Spark Adv. Reads 18 To 32 Degrees Of Timing When It Is Messing Up. It Comes And Goes And That Is Why I Am Thinking Knock.
Old 08-14-2007, 12:03 PM
when the car miss fires it jerks really hard and wont stop. and then out of nowhere the car run great?
Old 08-14-2007, 12:05 PM
anybody help please! you comments viewed as a solution! thank!
Old 08-17-2007, 08:02 AM
does anybody know what is wrong
