trouble with 1st gear
ok so I just finished putting in the LS7/LS2 clutch setup along with new slave, and a full master from GM dealer. Clutch is SMOOTH and drives great but I can not down shift into 1st gear unless I am doing like 5 miles per hour, or at a complete stop. If I push the pedal in and try to put it into gear right away it grinds but if I wait a second or two it goes right in. No other gear has any trouble. I didn't use a shim but was told that some do and some don't but the car fully disengages when the pedal is pushed in.....
Was thinking maybe I just need to bleed it again, the pedal does feel a little to soft anybody got any ideas
bled clutch again, still having issues with downshifting into 1st but now clutch pedal is a not as soft and engages about 1/4 to 1/2 way down
1st gear thing is still boggling me
