Door seal issue
Door seal issue
Theres a window "seal", i guess you would call it. Its on the outside of the car, its a long black rubber strip. Apparently the end of it (towards the back of the door) does not want to stay flush to the car. I'm guessing this is because of the windows going up and down more on the driver's side, eventually tearing it up. I've tried buying other window seals and playing with the clips but nothing seems to really WORK. Does anyone have any suggestions? I can provide pictures if necessary.
someone respond to this! i think i have the same problem its a pita. the exterior window seal, black rubber strip that seals between the window and door panel. mine isnt flush with the door panel any more, its really annoying and a pita to try and fix i havent had any luck.
