cooling fans not turning on
So my electric cooling fans aren't turning on at all. I just replaced the radiator and I don't think I disconnected anything from the fans, but the car has been disassembled for almost a month so if I did I don't recall.
The 2 connections that connect to each of the fans are connected and the fuse is good. Are there any more connections to the fan assembly?
Originally Posted by 2001NBMZ28
Did you go through shoebox's guide? Maybe the ECT sensor got damaged or is unplugged? I'd try jumpering the DLC pins and see if they come on.
My car did this recently. The right fan would come on with the A/C. It turned out to be the fan #1 relay. Hope this helps. Also, you can remove the relays and jumper the pins to make sure the fan works. Just make sure you use a fused wire and/or have plenty of fuses available. You can also disconnect the fan in question and hook it directly to the battery, same difference. Good luck......
Originally Posted by whattasickie
so where's the DLC and what pins are they?
