Common leaks on 99 F-bods
Something is leaking from under my car. Not antifreeze not rear oil not motor oil. It is clean looks like new oil. Is this oil from my trans. Its a M6. Is there a common leak on 99 F-bodys with 75k on them Just asking because I have not ben able to look under there yet.
I got 87k miles and no leaks. I don't think theres a common leak. Its definitely oil though right? It's not from your a/c? The only way to find out is park it overnight on a clean spot. Maybe some cardboard, and jack the car up in the place you let it sit and look under it to find the source.
Dexron 3 is RED...
If it is coming from the BACK of the transmission, near the driveshaft, it is transmission fluid. It is most likely a rear transmission seal. I'd recommend the GM OEM replacement, although an AutoZone piece is significantly cheaper, the difference in quality and sealing is miles apart.
