Bogging..feels like no fuel is getting to the engine
Old 08-24-2007, 09:23 AM
MidwayAvenue's Avatar
Default Bogging..feels like no fuel is getting to the engine
Lately after i start up the car and start driving the car hesitates when i start to give it gas feeling like there isnt any fuel going to the engine...bogging real bad so i let go of the gas and then press it again...it only does this usually right after starting up the car...
any ideas would be greatly appreciated thanks....
also what would happen if the knock sensor went such as due to headers (other possible problem)
thanks
Old 08-24-2007, 09:29 AM
5301113's Avatar
check to see if its not a vacuum leak
Old 08-24-2007, 07:53 PM
3.4camaro's Avatar
sounds like you need new plugs and wires.
Old 08-24-2007, 11:34 PM
ErikElvis's Avatar
So no CEL's? Ever changed the fuel filter?
Old 08-25-2007, 04:46 AM
IGNANt's Avatar
ive had the same problem... check your grounds, especially the one behind the driver side head. you give it gas, the motor moves/shakes pulling on the wire... it might be loose or corroded somewhere...
Old 08-25-2007, 01:21 PM
i changed plugs, wires, and fuel filter in april so all that should be good...
i'll check the grounds and look for a vacumm leak..thanks
anyone else have any ideas
Old 08-27-2007, 07:17 AM
vidal77boxing's Avatar
clean your maf sensor
Old 08-27-2007, 10:09 AM
Jon5212's Avatar
Do what everyone else has said, pick up a fuel pressure gauge and hook it to the fuel rail, you should be around 58 PSI.
Old 08-27-2007, 06:56 PM
i went to advance and had them pull up some codes from my ses light
they said slow o2 readings
could this be a cause to the problem
and what does that mean exactlt and what do i have to do now?
thanks everyone
Old 08-28-2007, 08:05 PM
Viper's Avatar
Means it could be time for new O2 sensors. I had the xact symptoms as you, replaced both of them with Bosch 13111 from Autozone, car runs great now.
Old 08-28-2007, 08:30 PM
that sux...cause i just put new ones in back in april...but the regular stock ones with extensions...but i guess the headers messed them up
thanks for the help
Old 08-28-2007, 10:31 PM
frisky2101's Avatar
had a sim problem a few weeks ago, changed both O2s and it still bogged and kicked flashing SES light.... Checked all the plug and wires and as I got to number 8 coil I touched the wire and it fell off the plug (DUH) hooked it all back up and no problems since
