Need some quick help with idler pulley issues
Old 08-25-2007, 10:34 PM
RedRocketZ28's Avatar
Default Need some quick help with idler pulley issues
So I was getting a pretty bad squek noise, not a belt squeak but something else. Slipped the belt off and the idler pulley was pretty loose. Bought a new one, put it on, and that solved the issue. I drove the car for maybe 15 mins and then it started squeaking again, this time it sounds like a belt squeak. The car also drops way down on the RPMs then comes back up. Could the belt be on too tight or something? Is there a recommended torque spec for the pulley? It starts to squeak when the engine gets over 2k. I am heading to the track tomorrow morning and need to get this resolved before the AM. Thanks all.
Old 08-27-2007, 07:31 AM
98LS-WON's Avatar
Pull the belt off and spin your alternator by had. Mine did that because the bearing was on the way out.
Old 08-28-2007, 04:15 PM
Took the belt off and spun everything. Nothing makes any noise. Also, when I spray some lube on the belt it stops squealing. It eventually comes back though. So, if I change the belt I should be good to go correct? Thanks all.
Old 08-28-2007, 04:24 PM
Danny2tek's Avatar
sounds like the belt
