Dirty oil between 1,500k oil change?
Old 08-26-2007, 12:50 PM
arrowhead87x's Avatar
Default Dirty oil between 1,500k oil change?
My 99 z28 with 78k and good maintance records. I changed my oil and filter with castrol syntec 5w30 and 2 months and 1500 miles later my change oil light came on so I changed the oil. Sure enough the oil was very black. This can not be a good sign with such little time and milage between changes. Why is the oil so dirty? Does the engine need attention?
Old 08-26-2007, 01:29 PM
waldershrek's Avatar
You should seafoam it and I can almost guarantee that your problem will go away.
Old 08-26-2007, 10:41 PM
Dan
Dan's Avatar
seafoam might be a good idea, I was in the same situation..oil seems much cleaner now..If you modded the car it could be running rich & causing a lot of carbon buildup
Old 08-26-2007, 11:04 PM
motownZ's Avatar
dirty oil aint really that bad, that somehat new but that just means its doing its job
Old 08-27-2007, 11:08 AM
keliente's Avatar
Did you reset the change oil light when you changed the oil the first time?
Oil gets discolored, fast, I am not surprised it looked dirty at 1500 miles.
Old 08-27-2007, 05:03 PM
How do I re set the oil light? I changed my oil but the light is still on. It should not be running rich, I just have the Slp air intake kit and an exhaust, not mods to the cats and stock manafolds.
Old 08-27-2007, 08:26 PM
Dan
Dan's Avatar
turn the ignition to on(don't start) Hold the reset button 15sec or when it turns off..every car is different, my 99 runs as clean as a whistle, the oil always look good when I change it.
Old 08-28-2007, 01:22 PM
Okay thanks. I will try the Seafoam to see if that helps.
Old 08-29-2007, 03:25 AM
Turn the key foward to "on" but do not start. Press the gas pedal down three times in a row quickly and you should see the light go off.
Old 09-07-2007, 07:36 PM
Ironxcross's Avatar
strange, im about to change my oil (its been 3000 since the change), its just a tan brown. I did seafoam it a year ago, i think that was definately a step in the right direction, the motor seems to run alot stronger now than it did before.
but if its not black by 3000 miles on a 112k motor, i guess that means im in good shape?
Old 09-09-2007, 12:34 AM
lostsurferguy's Avatar
Whats sea faom a engine degreaser or something that goes in the oil?
Old 09-09-2007, 09:00 PM
crapyboy750's Avatar
Click on the STICKY at the top of the general maintenance thread. Labeled HOW TO SEAFOAM YOUR CAR.
