window motor
window motor
i am having troubles getting my window motor out on my drivers side im following the manufacters service manual and having no luck does any have any advice so far it is a pain goin no where
thanx
thanx
Copy & Paste Moderator
Just did this today. My local Autozone had two different motors, both under the same part number (one of which was listed as the Siemens part number).
I work in automotive and know Siemens to be a decent automotive supplier.
But the Autozone dude brought out two different motors, in different boxes, under the that same part number.
Both were made in South Korea (which is ok but not ideal).
One was an OEM type, all steel construction. The newer looking design had a cast aluminum body and appeared to be of better quality in terms of the composite parts and overall design.
So, I think there is a new style design out there that might have some merits over the all-steel OEM style design. I am not sure how much sealing integrity (from moisture) has to do with the motor failures, but if so, I think the new design should be quite a bit better.
I went with the new design based upon the design features, and the fact that it also included mounting bolts with lock washers, which the other motor did not. I'm not sure if one is really that much better than the other, but if you know much about automotive parts, it doesn't make sense to tool up to make a different design, so there must be some reason that drove the use of the new design. Especially since the aluminum body has to be more costly.
Take care when buying.
yeah i had to replace one window motor on my old 95 Formie and both of them on my T/A...such a pain, but very easy once you do the first one. I used the Shbox walkthrough and had absolutely no problem...i would say the most frustrating thing is lining up the gear for the new window motor in the space it fits in inside the door. From start to finish it took me about 30-40 minutes.
