Low coolant lite
Low coolant lite
The low coolant lite come on about a week ago, so I check it and its low. Go and buy the orange Dex-cool and fill 'er up. Then yesterday, only two days agfter I fill it up, the damn lite is back on but the coolant is full. Whats up with this damn lite? I know this is a common problem, but how can I permanently fix it? Also does the dex-cool evaporate or something b/c it seems to go fast. Thanks.
you need to replace your coolant level sensor, it is on the passenger side if i can recall, you might be burning a little coolant but you do loose some naturally through that pores in the aluminum after extended periods of time.
i was told by the forum that you just have to take the battery out and a metal clip holding the sensor on if you want to clean it. and don't forget to drain the radiator to a level below the sensor so it doesn't come squirting out all over the place before you take it out.
