both window motors went out
hrm.. quick question .. my passenger window motor is starting to die.. i just did the autotrix mod and didnt save it.. it still gets stuck when going down / up.. now my driver side is doing it.. is there some kind of coincidence that both are going out at once?
Closed ex-Sponsor Account
Try to make sure that physically, the windows are able to somewhat freely move up and down- lubed tracks,no bent regulator arms. There could also be a problem with your master window switch- I have read instances where the switch is cracked and causing a bad connection.
Underneath, you would need to pop the bezel out, then remove the switch and inspect. Could be anywhere on the black plastic on the switch; this is just a guess though. G/L!
