Knock sensor code help.
I have a code about the knock sensor P0332 to be exact. Can someone enlighten me on how to fix it? Honestly I have no clue where to look for this.
There's two knock sensors, both are located under the intake - you're throwing the code for the rear one. You can look up the code description/diagnosis for your year at gearchatter.com ls1howto.com has an intake removal guide, if you need to replace it I'd do both sensors while the intake is off.
