Window
Window
Ok I think this is the right section. I just put some new stabilizers on my driver side window. Now when I go to roll the window up/down it does it in spurts. It will go a little bit then I have to wait about 30 seconds and it goes a bit more and so on. And everyonce in awhile when you move the switch either way then you here this sound coming from under the steering wheel area Any suggestions?
Are the stabilizers too tight? Might also be just a coincidence and the motor is going? http://shbox.com/1/adj_window.html
Closed ex-Sponsor Account
The clicking/poping is most likely your circuit breaker for the window circuit. You may have a bad drivers side window motor. shoebox has a great run through on how to replace your window motors.
Could be a couple of things. If your window motor is overheating it will stop and you'll have to wait a minute before it will work. Could be time for a new motor or your window is binding up causing the healthy motor to "overheat", tripping it's internal thermistor . The clicking noise under your dash could also be a result of a bound up window, but i would think the thermistor (correct?) in the motor itself would trip first, therofore no signal would go to the control relay under your dash. Usually i fyou listen closely you will hear most relays "click" when they're powered open or closed.
Sounds to me like you need to check the alignment of your regulator.
What all did you mess with when you replaced your stabilizers? and what exactly are you reffering to when you say stabilizers?
https://ls1tech.com/forums/appearance-detailing/742699-window-alignment-write-up.html
