volt meter prob
Old 10-04-2007, 10:54 PM
luv2sk8te17's Avatar
Default volt meter prob
volt gauge drops crazy. below the yellow. tried new alternator...nothing. got my stock one tested. it was fine. replaced and checked all connections and checked for corrosion. nada..out of ideas....even have new batt....also took off all extra stuff like nitrous connections and amp...any help would be awsum..thanx guys
Old 10-09-2007, 07:06 PM
so i replaced the "excitor wire".now voltmeter is fine once i start up. but when i take off the e-brake & hit the brakes it drops down 2 yellow. when a/c/ comes on its even worse....any guesses now? thanx
Old 10-09-2007, 08:30 PM
HoLLo's Avatar
Gotta be in the wiring.. The wire going from the alternator to the battery was rubbing my alternator, almost cutting straight through. I had similar problems.
Old 10-09-2007, 08:42 PM
ill definately have to check deeper on that wire....thanx 4 the input!
