Headlamp grinding - LS1TECH
Headlamp grinding
Thread Tools Search this Thread
Old 10-05-2007, 10:01 AM   #1
jclaassen2's Avatar
Default Headlamp grinding
The other night one of my headlights wouldnt pop up on my 98 Trans Am so i manually raised it and played with the connections and it started to work again except now it'll raise fine and when i close it, it sounds fine until it gets all the way closed then sounds like the motor is still trying to close the lamp and it just grinds until i turn the light back on and pop it up. The only way i could get by this is by disconnecting the power to the lamp so it stayed up and then i was finally able to shut my lights off. Any idea on what this could be? I wouldn't think its the gears because they sounds fine.
jclaassen2 is offline   Reply With Quote
Old 10-05-2007, 11:10 AM   #2
Danny2tek's Avatar
Please read my sticky in the Firebird/Trans Am forum...........
http://www.ls1tech.com/forums/showthread.php?t=177470
Danny2tek is offline   Reply With Quote
Tags
98, closed, closes, closing, constantly, dims, firebird, grinds, headlight, headlights, manually, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
